[ANSYS Meshing] Meshing: Finned Tube Heat Exchanger.
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   August 16, 2018, 03:37
Default Meshing: Finned Tube Heat Exchanger.
fulcrum is on a distinguished road
Hello, I'm new to Ansys.
I need to model heat transfer in a pipe-in-pipe HE.
Inner tube has many thin extruded fins: 250 in total. Tube length 100 mm.
Now my question(s):
1) Is this problem solvable on a ordinary PC ? 6 GB of RAM, 2.3 GHz.
2) Any meshing methods advice before to start ?
Please see the attached pictures below.
fulcrum is offline   Reply With Quote
Old   August 16, 2018, 18:53
Gert-Jan
Gert-Jan will become famous soon enough
My first guess would be that it is not possible on your computer. I would start with an axisymmetric case in 2D (fluent), if you can get away with this simplfication (ignoring 3D effects.
Try ICEM Hexa to create the mesh.
fulcrum likes this.
Gert-Jan is offline   Reply With Quote
finned tube, heat exchanger, helix
[ANSYS Meshing] how to mesh circular finned tube heat exchanger plshelp ANSYS Meshing & Geometry 1 February 21, 2017 06:58
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
Helical tube in tube, heat exchanger sobzsunny1 Main CFD Forum 0 February 4, 2014 07:03
[ANSYS Meshing] meshing for dual cell heat exchanger sandeep sethi ANSYS Meshing & Geometry 0 December 29, 2012 10:19
Concentric Tube Heat exchanger (pipe in pipe) in 2D ckliew ANSYS 0 February 24, 2011 07:48
