September 5, 2018, 07:36 |
Regarding multiple blocking
Anil Kumar B
Rep Power: 7 |
Hello guys, I'm working with a complex geometry which cannot be meshed using single blocking. So, I created different blocks for each parts(5 blocks, where all the parts are connected). When the software asks me if I would like to merge or replace for each block when i'm creating...I clicked on merge option while creating each new block.,because if I replace then the work I've done is gone.
But when I import it into fluent for specifing boundary conditions and run the simulation. The result were not appropriate! Is that because I dint connected those blocks in the end!! If it is Yes, please tell me how to connect them. Or if it is for other reason, please guide me. Thanks, Anil |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] Correct blocking and Ogrid in ICEM | salumi | ANSYS Meshing & Geometry | 3 | November 8, 2016 10:10 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 16:22 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
