September 25, 2018, 09:06 |
Topo tolerance
Rep Power: 9 |
I am learning ICEM at the moment and really don't this tolerance. What is the difference between triangulation tolerance and topo tolerance? Can someone please explain the topo tolerance in simple words? I really don't get it. I figured out that when i am changing the triangulation tolerance my mesh is following curves "better".
Furthermore, is a triangulation tolerance of 1e-06 bad or needs more computational effort during calculation? How does it affect simulation time or even solution? |
September 25, 2018, 10:58 |
Sebastian Engel
Rep Power: 20 |
Hi balrog,
triangulation tolerance seems to be relevant for the geometry only. With decreasing triangulation tolerance, the approximation of a curve/surface, such as for a circle, improves. In ICEM this might lead to higher load on memory on graphics. But there is no direct impact on downstream processes. The topology tolerance is a property of the mesher; a tolerance which determines how far a line/face of an element is allowed to deviate from the (approximated) geometry. Triangulation tolerance usually improves "the fit" of a mesh because the mesher needs a discrete geometry (that's what i assume). Even though, a circle can be defined analytically, the mesh probably still need discrete entities. Best regards, Sebastian Last edited by bluebase; September 26, 2018 at 04:04. Reason: some grammar corrections |
September 27, 2018, 02:24 |
Great
Rep Power: 9 |
Thank you very much!
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
icoFoam Courant number growth problem | tdof | OpenFOAM Running, Solving & CFD | 12 | May 24, 2023 14:00 |
Biomass Combustion CFD error | mankaran90 | OpenFOAM Running, Solving & CFD | 12 | August 16, 2017 06:51 |
STL import is not working | zordiack | enGrid | 9 | July 1, 2014 14:49 |
[ICEM] Setting the Topo Tolerance (with a script) | ChristianF | ANSYS Meshing & Geometry | 2 | August 18, 2011 09:56 |
