[Other] BladeGen Angle view
Like Tree2Likes
  • 1 Post By elia_l
  • 1 Post By elia_l
Old   October 14, 2018, 08:35
Default BladeGen Angle view
elia_l is on a distinguished road
Hi all,
I'm new in this forum and I'm beginner with turbomachinery simulation. I'm trying to deal with BladeGen. At the moment I got stuck with some issue related to beta angle definition.
- For one of spans I defined beta angles distribution, close to trailing edge appears a vertical pink dashed line. What does this mean?
- After defining beta distribution at some defined span, it seems (but I'm not sure) the program gets by itself n-points in order to draw the foil at that defined span. Is that right?
Thanks in advance.
m_abdi176 likes this.
elia_l is offline   Reply With Quote
Old   October 22, 2018, 15:54
Hi all,
here attached a clarification image. I hope it will help you to understand what I need.
BYE
[BladeModeler] Bladegen Radial Impeller Wrap Angle - Help Required surajkashyap ANSYS Meshing & Geometry 1 April 5, 2019 13:24
[General] Determine Viewing Angle from a specific View Direction Artikodin ParaView 1 June 27, 2017 05:05
[Other] Stagger angle in bladegen mzha0001 ANSYS Meshing & Geometry 0 October 12, 2016 18:52
Theta angle definition in BladeGen Raul CFX 2 November 1, 2012 11:02
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
