October 14, 2018, 08:35 |
BladeGen Angle view
Rep Power: 7 |
Hi all,
I'm new in this forum and I'm beginner with turbomachinery simulation. I'm trying to deal with BladeGen. At the moment I got stuck with some issue related to beta angle definition. - For one of spans I defined beta angles distribution, close to trailing edge appears a vertical pink dashed line. What does this mean? - After defining beta distribution at some defined span, it seems (but I'm not sure) the program gets by itself n-points in order to draw the foil at that defined span. Is that right? Thanks in advance. |
October 22, 2018, 15:54 |
Rep Power: 7 |
Hi all,
here attached a clarification image. I hope it will help you to understand what I need. BYE |
[BladeModeler] Bladegen Radial Impeller Wrap Angle - Help Required | surajkashyap | ANSYS Meshing & Geometry | 1 | April 5, 2019 13:24 |
[General] Determine Viewing Angle from a specific View Direction | Artikodin | ParaView | 1 | June 27, 2017 05:05 |
[Other] Stagger angle in bladegen | mzha0001 | ANSYS Meshing & Geometry | 0 | October 12, 2016 18:52 |
Theta angle definition in BladeGen | Raul | CFX | 2 | November 1, 2012 11:02 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
