October 19, 2018, 04:29 |
ICEM Meshing issues
Danielchung
Rep Power: 7 |
Hi, I am relative new to ICEM Meshing,
The problem i'm facing now is when I mesh in ICEM CFD, I can isolate the mesh from the wall and to the fluid. But when I do it in Fluent, the 'int fluid' incorporate everything. I cannot remove the wall mesh at all! The reason is i want to see the fully developed flow inside and the wall is blocking it! Just a background, Im trying to simulate 3D flow down a plane. So basically 3 wall (2 on the side and 1 on the bottom) 1 inlet and 1 outlet and the top of the geometry is expose to the atmosphere. 1.jpg 2.jpg 3.jpg |
October 19, 2018, 04:54 |
Gert-Jan
Rep Power: 27 |
Looks like you did everything correct in ICEM So I don't think this is a problem of ICEM, but visualizing things in Fluent. I recommend to raise this question in the fluent forum.
icem cfd 14.5 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 10:28 |
[ICEM] ICEM sizing function >>> Gambit and Ansys meshing | Far | ANSYS Meshing & Geometry | 6 | March 5, 2013 01:16 |
ICEM Meshing - Memory issues. | DamjanStefkov | ANSYS Meshing & Geometry | 0 | May 25, 2011 01:38 |
ICEM: Projectile Meshing and Modelling Issues | gman89 | ANSYS | 0 | May 11, 2011 23:01 |
ICEM Meshing | Jaloha | CFX | 0 | April 1, 2008 06:24 |
