[ANSYS Meshing] Which meshing element is better in the of 2D inverted aifoil ? Tri. or Quad. ? Why |
November 20, 2018, 15:06 |
shivamhank
In meshing of an inverted airfoil in 2D using ANSYS 18.1 version, I would like to know which meshing element is better ? I've obtained both triangular elements with no multi-block and also quadrilateral elements with multi- block. The meshing quality is lower in the case of quadrilateral than that of triangular.
Could anyone give a descriptive explanation with the above case ? Thank You, Shivam |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
2d quad meshing | praveen | enGrid | 3 | March 30, 2018 03:53 |
[ANSYS Meshing] combining tri and quad mesh | luccy | ANSYS Meshing & Geometry | 0 | January 25, 2016 06:54 |
Meshing Ring Element | Jalen | ANSYS Meshing & Geometry | 2 | October 20, 2009 09:21 |
Calculating meshing element type | Ken | FLUENT | 0 | April 27, 2007 02:10 |
