[ICEM] Meshing a rotor blade with tip clearance
Old   December 9, 2018, 09:49
Default Meshing a rotor blade with tip clearance
Julian121 is on a distinguished road
I have been trying to mesh a rotor blade which has a small tip clearance.
After I created an ogrid block along the blade, I split along the span to separate solid and fluid parts.
I have faced these problems:
1- The blocks surrounding the leading edge of the blade and the blade itself seems to be lower than it should be. As a result, the mesh at the leading edge is slightly lower than the shroud curve. I tried to use face association between the upper faces of the blocks and the shroud surface but it does not change.
2- I need to split the shroud surface and assign different parts. Although I have defined two different parts, the mesh does not respect the defined surfaces.
I would appreciate any help.
Julian121 is offline   Reply With Quote
[ICEM] Meshing a sharp tip of an engine spinner lcaBR ANSYS Meshing & Geometry 4 April 1, 2014 13:11
Tip Clearance in Transonic Compressors Behnam.H.Beheshti Main CFD Forum 7 May 20, 2013 21:47
Meshing in tip clearance. me Siemens 0 August 25, 2008 03:20
grids in tip clearance iceraining Main CFD Forum 2 September 12, 2005 00:50
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
