December 16, 2018, 02:18 |
Problem in meshing a curve
Rep Power: 8 |
Guys,
Just trying to mesh a nozzle using non-biased mesh for the edges upper the curve of the ramp. After sizing the edges of my flow field and generating the mesh, I get such a part (within red circle) in my flow field: As you see, Ansys meshing has meshed this edge as it is biased while it's not biased. I don't get any error or warning about what's going on for the mesh. Odd behavior! |
December 16, 2018, 03:00 |
Rep Power: 8 |
Changed the behavior of meshing from soft to hard and the problem solved.
3D Cyclone meshing problem | Wayne12195 | Mesh Generation & Pre-Processing | 0 | September 25, 2018 01:45 |
[ANSYS Meshing] problem in meshing of Aerofoil shaped obstacles in plane channel. | lohith | ANSYS Meshing & Geometry | 0 | June 20, 2018 02:58 |
[ICEM] Meshing problem in Formula one | Far | ANSYS Meshing & Geometry | 113 | April 23, 2013 12:36 |
[ICEM] problem with meshing in icem cfd | saurabhjoshi2011 | ANSYS Meshing & Geometry | 13 | March 12, 2013 11:27 |
2D planar cylinder meshing problem | saisanthoshm88 | ANSYS Meshing & Geometry | 15 | December 27, 2010 11:14 |
