December 27, 2018, 09:16 |
Delaunay mesh fail
Niccolò
Rep Power: 7 |
Hi everybody,
I'm currently trying to generate a proper mesh for a vascular CFD simulation. The geometry is quite complicated but I have been able to obtain a tetra/mixed mesh through a robust-octree algorithm without any kind of problem detected by the ICEM check mesh tool. The problem arise when I try to convert the mesh into a Delaunay one starting from the existing mesh just generated. The process fails in the most cases and, when it doesn't, the generated mesh presents a very huge number of decets and errors. Does anybody has any idea about the reason for this? Thanks, Niccolò |
July 24, 2019, 07:57 |
Yashwant M
Were you able to find a solution for this problem? I am also facing a similar issue. |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] Create Delaunay mesh only for a specified material point | Andrea1984 | ANSYS Meshing & Geometry | 0 | October 13, 2014 09:25 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
