[DesignModeler] How to Determine flow domain?
Old   March 3, 2019, 10:52
Default How to Determine flow domain?
anonymousone1895
anonymousone1895 is on a distinguished road
Hi Everyone,
I am new to the cfd. so I have started small. I am trying to simulate supersonic flow over a wedge. the half angle is 20 degrees. I can't figure out to set the dimensions for the flow domain like inlet outlet and far field and my wedge dimension is one meter. please help and thanks in advance. how to take the dimensions?
anonymousone1895 is offline   Reply With Quote
Old   March 4, 2019, 10:26
Roh
Roh is on a distinguished road
What's your problem exactly? There are many toturials on the net that you can follow.
Roh is offline   Reply With Quote
Old   March 4, 2019, 22:26
Svetlana Tkachenko
Светлана is on a distinguished road
You will need to mesh the external domain.
Its size depends on the wedge geometry, the fluid properties, and the velocity of the fluid. If you specify these in reply, someone will be able to assist you.
Often you can find this by searching for existing published literature as they have many geometries already available as benchmark cases.
Светлана is offline   Reply With Quote
Old   March 8, 2019, 20:34
anonymousone1895
My wedge is of length 1 meter with a half angle of 20 degrees. Static pressure, static temperature and mach number behind shock wave are 1atm, 300K , 4.
Old   March 16, 2019, 09:55
anonymousone1895
can anyone reply please?
Periodic Pressure drop cfd_begin CFX 10 May 25, 2017 07:09
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 00:42
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
