April 22, 2019, 06:32 |
Long distance pipeline meshing
Said laarab
Hello everyone,
I'm working on a long-distance pipeline meshing on ICEM CFD, it's about 1000m long with many elbows. I have import the geometry from Solidworks as IGS file with no problem, then I create directly the mesh, using compute mesh section. the problem comes when I export the mesh file to fluent, it gives me this error message: Error: Build_Grid: no cells in case file. Clearing partially read grid. Error: Build Grid: Aborted due to critical error. Error: Build Grid: Aborted due to critical error. Error Object: #f I have read many posts talking about the same issue, but it still not clear to me. Do you have any suggestions? |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Icem meshing queries | Mfaizan | ANSYS Meshing & Geometry | 21 | July 30, 2015 23:10 |
[Gmsh] Meshing of thin and long plates | Evgeny | OpenFOAM Meshing & Mesh Conversion | 0 | May 18, 2011 06:36 |
