[ICEM] Cylinder with a deformed surface: Tri surface, only-Hexa interior |
April 26, 2019, 04:44 |
Rep Power: 7 |
I have been recently introduced to ICEM CFD and I wanted to create a mesh for my somewhat complex cylinder geometry. Desired properties are as follows: 1. Only "Hexa" elements in the interior and no Tetras (since they're not compatible with my solving methods in Fluent). 2. "Tri" elements on the surface to correctly handle the curves of the geometry (I mean not all-Quad, maybe few). 3. and I suppose few "Prism" elements representing the boundary layer to connect the tri and hexa elements. is it even possible ? My efforts yield no success to do this properly, despite searching and reading many threads regarding this kind of mesh. No matter how I change the settings, there will always be unwanted tetra elements there. I'd greatly appreciate any help. Capture.PNG Last edited by atafiroozi; April 26, 2019 at 05:10. Reason: question mark |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
surface integral at the interior surface!! | rajamanimech | FLUENT | 4 | August 20, 2013 02:13 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
Meshing interior surface in prosurf and proam | cfdengineer | STAR-CD | 0 | May 1, 2010 00:45 |
mass flow rate on the Iso-clip surface & interior | Sunil Gupta | FLUENT | 0 | April 22, 2008 09:29 |
