[DesignModeler] User defined curve surface geometry generation
Old   May 19, 2019, 09:11
Post User defined curve surface geometry generation
u_k
u_k is on a distinguished road
I am looking for some suggestions regarding generating a self defined spline or curve between two points and then revolving it about its axis to produce a venturi geometry.
My target is the shape optimization of venturi, for that i have to generate several curves/spline to study and optimize the shape of venturi (converging and diverging sections) in order to minimize the pressure drop and reversed flow/ turbulances.
How should i approach for generating curved line/spline that can be changed or parametrized?
Thanks in advance.
u_k is offline   Reply With Quote
OF-extend: area-averaged pressure drop across one patch and one user defined surface jgross OpenFOAM Post-Processing 0 February 19, 2018 14:03
[ICEM] How to cut the surface using curve delliganesh07 ANSYS Meshing & Geometry 0 August 11, 2017 12:03
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
