[ICEM] Two edges sharing the same two vertices |
May 22, 2019, 06:25 |
Lauren Dransfield
Rep Power: 14 |
I've encountered an issue when joining blocks together whereby I seem to have two different edges sharing two vertices, so I'm getting mismatched node counts.
I think it's come from how I've joined them and then merged some vertices to edges, but I'm not sure how I'd go about merging the two edges into one so that it appears as I'd initially intended. I've attached an image of the blocking with node counts and vertex numbers visible to show that there are only two vertices for the two edges, plus a clearer diagram of what I'm seeing with regards to the counts. Each block appears fine within itself, but where the yellow block and the blue block are connected, they seem to have separate edges between the two vertices. Last edited by ld1305; May 22, 2019 at 08:10. Reason: Simplification |
May 23, 2019, 08:51 |
Lauren Dransfield
Rep Power: 14 |
It seems like this is less likely to happen if the yellow and green blocks are already sharing vertices at either end of the blue block before merging the centre vertex to the ends, though I'm still not sure how I'm to fix those that are already broken.
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
