[ANSYS Meshing] mesh a surface of an internal wall within a volume
Old   July 22, 2019, 04:08
Default mesh a surface of an internal wall within a volume
Francesco
francescobabich is on a distinguished road
Dear All,
I used to use ICEM CFD to work on the geometry and create the mesh for CFX simulations.
Recently, I have started doing everything using the tools available within Workbench, namely DesignModeler and Meshing.
Unfortunately, I cannot find the way to mesh internal surfaces within a 3D domain (for instance, these could be plates within a 3D domain...see image attached as a very simple example to better explain the problem). In ICEM, I used to use the option "Internal wall" (https://bit.ly/2M5gmY0) to do so, but I cannot find an equivalent option using DesignModeler and Meshing.
Thank you.
Francesco
francescobabich is offline   Reply With Quote
Old   August 12, 2019, 08:45
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Francesco,
In design modeller how did you define the internal surfaces ? You have several options, I would start by using a boolean operator defining a given thickness for your surfaces and then cut your fluid enclosure.
It it's infinity thin you can also simply define a named selection in Ansys meshing and change the properties inside Fluent.
Have fun
Gweher is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
