[ICEM] Pre Mesh Intersects on 'Project Surfaces'
Like Tree4Likes
  • 1 Post By sacrover
  • 2 Post By Gweher
Old   July 24, 2019, 07:04
Question Pre Mesh Intersects on 'Project to surfaces'
Sachin Verma
sacrover is on a distinguished road
I am trying to mesh an external flowfield around a propeller using hexa blocking. The computational domain is divided into two parts:
1. Farfield (stationary frame)
2. Disc around the blade (Rotational frame)
I've split the blocks and used O-grids around the blade section. Everything is fine until I click Pre-Mesh>Project Surfaces. Grid lines are crossing each other almost everywhere along the blade. I've tried moving the O-grid vertices that are associated to the airfoil sections but there's no improvement. I've attached the screenshots.
Thanks for your help.
Светлана likes this.
sacrover is offline   Reply With Quote
Old   July 30, 2019, 05:37
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Sachin,
Looks like an association problem to me. Check if all your edges / vertices are associated to curves / points. Also under the pre-mesh you can either project to surfaces or edges so check the option you've picked.
Have fun
Gweher is offline   Reply With Quote
Old   August 8, 2019, 13:43
Sachin Verma
Thanks alot Gwenael. I re-checked all my associations and, more importantly, I split the blocks' edges (linearly and as splines) to align them with the airfoil sections. This ensured that the blocks conformed to the surfaces and, essentially, that it prevented any 'distortion' of mesh while projecting it onto the the surfaces.
Old   August 9, 2019, 10:08
Smile
Gweher's Avatar
Gwenael H.
Hi Sachin, great thanks for your feedback and good to know it worked!
hexa blocking, icem, o-grid, pre-mesh, propeller
[blockMesh] Sphere mesh with blockMesh - weird cells TheMadHungarian OpenFOAM Meshing & Mesh Conversion 1 October 22, 2018 09:03
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 13:28
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
