[ICEM] Pre Mesh Intersects on 'Project Surfaces' |
July 24, 2019, 07:04 |
Pre Mesh Intersects on 'Project to surfaces'
Sachin Verma
Rep Power: 8 |
I am trying to mesh an external flowfield around a propeller using hexa blocking. The computational domain is divided into two parts: 1. Farfield (stationary frame) 2. Disc around the blade (Rotational frame) I've split the blocks and used O-grids around the blade section. Everything is fine until I click Pre-Mesh>Project Surfaces. Grid lines are crossing each other almost everywhere along the blade. I've tried moving the O-grid vertices that are associated to the airfoil sections but there's no improvement. I've attached the screenshots. Thanks for your help. Last edited by sacrover; July 29, 2019 at 08:04. |
July 30, 2019, 05:37 |
Gwenael H.
Rep Power: 20 |
Hi Sachin,
Looks like an association problem to me. Check if all your edges / vertices are associated to curves / points. Also under the pre-mesh you can either project to surfaces or edges so check the option you've picked. Have fun |
August 8, 2019, 13:43 |
Sachin Verma
Rep Power: 8 |
Thanks alot Gwenael. I re-checked all my associations and, more importantly, I split the blocks' edges (linearly and as splines) to align them with the airfoil sections. This ensured that the blocks conformed to the surfaces and, essentially, that it prevented any 'distortion' of mesh while projecting it onto the the surfaces.
August 9, 2019, 10:08 |
Gwenael H.
Rep Power: 20 |
Hi Sachin, great thanks for your feedback and good to know it worked!
hexa blocking, icem, o-grid, pre-mesh, propeller |
[blockMesh] Sphere mesh with blockMesh - weird cells | TheMadHungarian | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2018 09:03 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 13:28 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
