[DesignModeler] 2D geometry, surfaces doubt
Old   July 25, 2019, 14:00
Default 2D geometry, surfaces doubt
Victor Ameno Cautela
vcautela is on a distinguished road
Hello to all!
Im a new user of cfd-forum and also a new user of Ansys.
Im currently working with Ansys Student 2019-R2
I'm trying to simulate a sudge tank cleaning and having problems with adding some surfaces..
First I divided the tank area and create two different surfaces for adding sludge and air in the materials
then, I draw a vertical pipe(in the same sketch) for the sludge draining, but I canīt create a surface as the error shows..
I Attached some pictures for better visualization.
I apologize for my bad english and for the so basic question, but I'm having trouble to solve this geometry..
Thank you guys!
vcautela is offline   Reply With Quote
Old   July 28, 2019, 04:54
M.Eid
MaherEid is on a distinguished road
Are you using the Add Material option in the Operation tab?
MaherEid is offline   Reply With Quote
Old   July 29, 2019, 09:58
I am Still in the geometry process, the question is, the edges that compose the pipe for suction have a dark green color and I cannot define any surface.
The Materials definition goes on the fluent solver, isn't it?
Im still on Design Modeler
Thanks for the reply!
Old   July 30, 2019, 02:52
M.Eid
To generate surfaces you use a feature called Surface from Sketch in Design Modeler.
In this feature you have to input add material or add frozen
If you are using the add material change it to add frozen and your problem should be solved.
Old   July 30, 2019, 09:12
Hello to all!
Guys, Thank you very much for your interest in help me with my question.
That's it, Now I can mesh these two parts separately with the ADD FROZEN option.
Some pictures attached for better visualization of the process
[Workbench] Workbench 18.2 SpaceClaim->Mechanical geometry accuracy/tolerance problem sultzan ANSYS Meshing & Geometry 0 December 13, 2018 17:41
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[ICEM] Issue creating geometry and trim surfaces M4x1m ANSYS Meshing & Geometry 1 February 9, 2015 08:38
[ICEM] Cleaning Rippled Surfaces in ICEM scribby182 ANSYS Meshing & Geometry 3 December 11, 2012 16:34
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
