July 31, 2019, 15:34 |
ANSYS meshing error
alok
I have designed a geometry in ANSYS workbench 19.2 for motive to analysis the pressure in the geometry. I am getting an error during meshing (the mesh generation didn't complete) and geometry taking to much time in meshing. please, anyone, suggest proper guidance. Geometry attached in link below https://drive.google.com/open?id=1nK...w2S5wp--z-giru |
July 31, 2019, 22:18 |
Svetlana Tkachenko
Rep Power: 14 |
If I am not mistaken in ansys 19.1 it says "PlugIn Error: Failed to import assembly from SpaceClaim. Operation failed."; can you export it in another format?
August 1, 2019, 17:11 |
M.Eid
Rep Power: 8 |
Can you screenshot the mesh and the error?
August 8, 2019, 02:43 |
got solution
alok
Belated see the massage but thanks for the reply.
There was a contact defining problem which solved but I do not find a pressure inside the enclosure up to 10 bar because solution parts take to much time so please help me to find the solution. The link is given below https://drive.google.com/file/d/1-9u...ew?usp=sharing |
August 8, 2019, 13:43 |
Gwenael H.
Rep Power: 20 |
Hi alok,
I had a quick look at your project files and there was no problem importing all the parts and creating the mesh (I just left the default sizing). Not sure about the problem definition and what you are trying to solve ? |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
