[ICEM] Filling the hole in existing mesh with tet elements
Like Tree1Likes
  • 1 Post By michal.s
Old   August 12, 2019, 11:22
Default Filling the hole in existing mesh with tet elements
Michal
michal.s is on a distinguished road
Hello there,
The problem I am facing is probably not very complicated, but I haven't found a solution yet...
I am simulating the flow over a turbine blade. My mesh is a quite decent 3D hexa type mesh prepared in Icem with C-grid topology.
However, in the current step I should include that thin clearance between the blade tip and the duct surface. For that reason, I was trying to fill this clearance with some tet elements (blocking is not a good idea, since the C-grid topology was used). To have good results and to avoid any further problems, I am trying to generate conformal mesh.
I was trying to use free blocks (not possible, since I have created C-grid), generate tet elements separatelly and then merge them with hexa mesh.
Any suggestions if there is some option to generate volume mesh from the surface mesh already generated?
Kind regards,
M
Thural likes this.
michal.s is offline   Reply With Quote
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
