[ANSYS Meshing] Need help in fixing drop in mesh quality due to creation of stairstep mesh |
September 1, 2019, 02:41 |
Hitesh
Rep Power: 11 |
After adding inflation I'm getting this error - "Inflation created stairstep mesh at some locations." and the mesh quality is decreasing. What can I do here to improve the mesh quality? I am tinkering with gap factor and maximum angle (lowering their values) and it helps but only to a certain degree. |
September 1, 2019, 09:56 |
Gwenael H.
Rep Power: 20 |
Hi Hitesh,
You have two options. Either play around with the inflation options (first layer height, growth rate, max height over base, etc...) or you can also split your geometry in design modeller / spaceclaim > form new part / component, then assign a multizone method to the triangular shaped bodies with an inflation. Have fun |
September 3, 2019, 04:58 |
#3 | |
Hitesh
Rep Power: 11 |
So rest of the body tetrahedral but triangles as multizone? Wouldn't this lead to issues because of tet to hex transition. I have tried this before and the results were not great |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[ICEM] Unexplained changes of mesh quality and blocking approach | salumi | ANSYS Meshing & Geometry | 9 | November 23, 2016 04:14 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
Different types of Mesh quality | hagupta | CFX | 1 | June 30, 2006 07:42 |
