[DesignModeler] How to draw a wavy wall in DesignModeler |
September 9, 2019, 10:11 |
Rep Power: 16 |
Hello all
I am trying to draw a wavy wall in an enclosure using DesignModeler with a fixed amplitude A as shown in picture? may somebody guide me how I can do that? Mariam |
October 6, 2019, 14:49 |
Gwenael H.
Rep Power: 20 |
Hello Mariam,
There is no direct way to draw such a profile in design modeller ... In Spaceclaim you can use the build in equation function to create your profiles directly but not natively in design modeller . A walkaround would be to generate a text file with point coordinates of your profile (in matlab/excel for instance) and import the txt file in designmodeller. The structure of the text file should be abxyz a: group number (must be an integer >=1) b: point ID number (integer >=1) xyz: coordinates (depend on DM system units) Have fun |
Use PointWise to create a wavy wall | hopehope | Pointwise & Gridgen | 6 | March 4, 2020 16:24 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
