November 17, 2019, 23:25 |
Angle below 18 degrees solution?
Lolita
Rep Power: 9 |
hi,
I was meshing a bottle shown in Fig. 11.11.png I had used O-grid 12.png13.PNG. I am getting angle below 18 degrees mostly at the bottleneck14.PNG15.PNG. Kindly suggest some solution. regards |
November 18, 2019, 01:25 |
M
Rep Power: 12 |
Would it not be easier to create a 2d-mesh and extrude/rotate it about the axis?
November 18, 2019, 01:39 |
Lolita
Rep Power: 9 |
November 18, 2019, 03:10 |
M
Rep Power: 12 |
I never tried it because my geometries are usually not symmetrical, but with this I would definitely try. I would be curious to see your results there.
November 19, 2019, 06:51 |
Sebastian Engel
Rep Power: 20 |
Please create a screenshot of the cross section
Use "scan planes" to create a section and show us the corner region in more detail. You'll find scan planes in the context menu of premesh. |
[snappyHexMesh] No generation of layer onto zerothickness surface | crubio.abujas | OpenFOAM Meshing & Mesh Conversion | 3 | October 25, 2022 03:20 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
