[ICEM] Block-structured mesh around multi-element airfoil using ICEM |
November 29, 2019, 05:41 |
Rep Power: 6 |
Hello everybody,
I have been trying to use ICEM for making a 2D block-structured mesh around a multi-element airfoil. I am however having some troubles. My strategie is to make a C-grid around the two airfoils and then a O-grid around each individual airfoil as shown here: icem1.jpg icem2.jpg However when I am visualising the pre-mesh, I realize that some of the mesh don't respect my blocking. As can be seen below: ICEM3.jpg The mesh seems to be influenced by the shape of the airfoil even if the edges of the blocks are not linked to the airfoil. I would like to get rid of this problem in order to have the flow and the mesh in the same direction. Any help would be greatly appreciated. |
ICEM for dual airfoil structured mesh | jiadongw | Mesh Generation & Pre-Processing | 0 | July 19, 2018 06:09 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
[ICEM] Blocking strategy for a Multi Element Airfoil (ICEM) | mix | ANSYS Meshing & Geometry | 16 | January 17, 2016 13:41 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
