February 18, 2020, 05:16 |
Unsupported topology FENSAP
Zhandos Baizhuma
Rep Power: 6 |
Dear all, I am trying to simulate VAWT icing using FENSAP-ICE. I have created mesh using Pointwise. it has two domains: farfield and rotating. Also there are interface zone between them.
In fluent it works well both MRF and Sliding mesh. But when I comes to FENSAP I am not able to set blade walls as rotating walls. "Unsupported topology" message appears. Pls can you share if you have any idea? You can find my case file below https://www.dropbox.com/s/yb6hat3jv3...ation.cas?dl=0 |
February 18, 2020, 18:01 |
Svetlana Tkachenko
Rep Power: 14 |
It looks like this message has been posted in the wrong forum. This is ansys meshing, not fensap.
February 19, 2020, 03:27 |
Zhandos Baizhuma
Rep Power: 6 |
There is no special FENSAP forum as I see.
Fensap is a component of fluent and my problem is related with mesh, thus I posted it here |
July 10, 2021, 00:27 |
Hi.
I was wondering if you found a solution to this. I have been having the exact same issue and I haven't been able to figure out how to have my turbine rotating. I am trying to simulate icing on a VAWT (Savonius) as well. Any help is much appreciated. |
[TurboGrid] problem with topology | verinna | ANSYS Meshing & Geometry | 3 | July 12, 2021 07:28 |
Turbogrid Topology Generation Issues | t8fanning | CFX | 0 | November 6, 2019 11:37 |
[ANSYS Meshing] Selective Shared Topology / Conformal Mesh | Richard Renaud | ANSYS Meshing & Geometry | 2 | November 25, 2015 19:58 |
[TGrid] Water Turbine meshed in TurboGrid: Geometry and Topology issues | ama294 | ANSYS Meshing & Geometry | 12 | September 29, 2014 13:23 |
[ICEM] Shifted Periodic topology | venkat_aero2007 | ANSYS Meshing & Geometry | 17 | August 27, 2013 01:41 |
