[ICEM] Correct Meshing Strategy
Old   March 20, 2020, 04:31
Default Correct Meshing Strategy
James Adams
hugzmeister is on a distinguished road
Hi Folks,
I'm a little stuck with my current mesh.
Its got a complicated geometry and I was wondering if anyone has any advice on how I could improve the meshing.
I have ran it on a rotational Re of 1e7 and it does not converge. After many meshing changes, I still could not get it to converge. I have tried reducing the Rotational Re to 1e6 and it just about works, but I need tohave it at 1e7.
Let me know what you think.
File Type: pptx Model Divergence Problem Description1.pptx (152.9 KB, 9 views)
hugzmeister is offline   Reply With Quote
Old   March 21, 2020, 11:07
M
AtoHM is on a distinguished road
In the images I cant see a complex geometry at all. Is that just a cut view?
Your cells are very flat and the grow ratio away from the refined region seems to be quite big. Can you not just avoid the huge elements and add more cells along the edges? The refined regions seem ok and the blocking looks fine from what I can see.
AtoHM is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials denbjornen OpenFOAM Meshing & Mesh Conversion 1 May 25, 2020 11:14
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 11:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] 3D Meshing strategy : a bay Magicano ANSYS Meshing & Geometry 0 January 3, 2013 19:02
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 12:45
