[ICEM] No "apply" button" on Trying to rotate a block |
March 21, 2020, 20:44 |
Hazem
Rep Power: 6 |
Dear members,
I know this may sound simple but I've been stuck here.. I'm trying to create a hex mesh for a 3 blade wind turbine. Using slicing I made a block surrounding one blade (since the blade is horizontal) and saved it as a part in the tree "BLADE_1" Now I need the two other blades to have the same block, I'm trying to use rotate block, I selected the block and entered all the options and can't find the apply button and the middle click doesn't do it also. A Any help Regards, Hazem |
[blockMesh] Velocity,Pressure locked in Blocks | Tobi94 | OpenFOAM Meshing & Mesh Conversion | 2 | December 31, 2019 08:27 |
[ICEM] Rotated the Blade and was unable to rotate the respective mesh block | juzer_700 | ANSYS Meshing & Geometry | 2 | July 30, 2015 04:45 |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
