[TurboGrid] Including a hub region in blade passage
Old   June 17, 2020, 12:01
Default Including a hub region in blade passage
Peter
Petercm4 is on a distinguished road
Hi everyone,
I am working with mixed flow turbines but would like to include a hub region to use as an interface for a backdisk cavity mesh. I am using the academic version of TurboGrid as I am a student. The turbines have inlet, blade and outlet passages.
I have created this hub region within the inlet passage but this means the interface between the inlet and blade passages is incredibly close to the leading edge of the rotor (Configuration A). This configuration has caused the cells to become closely packed near the leading edge. I have images of the closely packed cells, the blade passage is blue and the hub region is green.
I would like to move the interface upstream of the rotor to include this hub region in the blade passage to improve the distribution of cells near the leading edge (Configuration B). I have attempted this but get an error stating a point in the hub region is within the blade passage. I was wondering if anyone has attempted this or knows of a method that could resolve this issue.
Thank you for any suggestions
Petercm4 is offline   Reply With Quote
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 15:53
[ICEM] Structured mesh in fan blade passage joygiak ANSYS Meshing & Geometry 0 November 23, 2017 05:34
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[TGrid] Inlet passage in turbogrid. soldimix15 ANSYS Meshing & Geometry 0 September 5, 2010 11:34
[ICEM] Blade passage block mesh in ICEM Attesz ANSYS Meshing & Geometry 4 February 13, 2010 04:53
