[ICEM] ICEM hexa bunching question: number of nodes and pre-mesh display |
April 5, 2021, 04:55 |
zuheyr alsalihi
Rep Power: 7 |
Happy Easter!
Please do forgive my silly question but I am baffled: newcomer to ICEMCFD, in a simple 2D mesh with Hexa, I give 3 nodes along an edge in the bunching, and the pre-mesh plot shows me 11 grid points along that edge. Please tell me what is happening? I checked the manual: Nodesspecifies the number of nodes along the edge. The number may be modified using the up and down arrows or by entering a number in the field. I give 3 nodes, pre-mesh plots 11? Thanks for reading! Kind regards and best wishes! |
April 6, 2021, 09:20 |
Kira
Rep Power: 8 |
Could you please attach a photo of the line with 11 nodes, and a picture of the GUI where you specify the number of nodes and the mesh law? |
April 6, 2021, 10:12 |
Photos of the bunching and pre_mesh
zuheyr alsalihi
Rep Power: 7 |
Thank you *so much*
I attach screenshots which I hope are visible. I can send pictures by other means as well if not clear. I also tried hyperbolic etc, the same. The pre_mesh picture is from What is so critical to me is what pre_mesh is plotting really? So important to understand this. Thank you so much! Best, Zuheyr Last edited by zuheyr; April 6, 2021 at 10:17. Reason: Attached uniform and hyperbolic bunching edge informations |
April 6, 2021, 15:22 |
Sebastian Engel
Rep Power: 20 |
Hi Zuheyr,
it is likely, that you blocks have a refinement level which is not 1. In the meshing parameters menu (3rd from the left) you show in your screenshots there is a button to show and modify the refinement levels of blocks(5th from the left). You likely need to set the refinement back to 1 for the respective blocks. Best, Sebastian |
April 6, 2021, 15:49 |
zuheyr alsalihi
Rep Power: 7 |
Sebastian you were right! It was 0.5!!
In fact this brings about a very important concern of mine: I need to make a 3 times refinable mesh for refinement study. it is a 2D mesh. What is the best way of achieving this? There is also a possibility to set a fixed multigrid level, such as 3. I am grateful to you! Thank you. Best wishes, Zuheyr |
April 6, 2021, 16:08 |
#6 | ||
Sebastian Engel
Rep Power: 20 |
I think, I don't fully understand what you mean.
Consider refinement levels as a post processing step of the edge parameters---they only have a one-way dependency to the edge parameters. |
April 6, 2021, 16:16 |
zuheyr alsalihi
Rep Power: 7 |
That is a perfect clear explanation. Thank you very much. Best wishes, Zuheyr
April 12, 2021, 04:03 |
Coarsening is also possible?
#8 | |
zuheyr alsalihi
Rep Power: 7 |
I ran into a problem that perhaps you can please help: Can I use the bloack refinement you mention in the meshing parameters menu, the 5th icon, by using a refinement level less than 1? Strangely when I was mistakenly using 0.9, as you have caught, it was working, when I make a good mesh and want to *coarsen* it, I get a cryptic error message saying the factor must be positive! Can I do coarsening? Thank you so much for reading! Zuheyr |
April 12, 2021, 15:39 |
#9 | |
Kira
Rep Power: 8 |
I have had this problem before and found a way to solve it. You need to input a fraction (i.e. 1/2) rather than a decimal (i.e. 0.5). |
April 14, 2021, 08:13 |
#10 |
zuheyr alsalihi
Rep Power: 7 |
Dear Kira,
Thank you, you once again saved me. Although much to my surprise I unhappily discovered in these forums that refinement is creating hanging nodes whatever they may be, which Fluent ignores but i am using a normal solver and it does not. This will be another thread I will ask for help. I just mention it here for the unawares like me. Kindest regards, Zuheyr |
April 14, 2021, 09:55 |
#11 |
Sebastian Engel
Rep Power: 20 |
Hi Zuheyr,
Kira knows your struggle for sure. =) Maybe this thread is interesting to you, too: Different Levels of Refinement in Adjacent Blocks Best, Sebastian Last edited by bluebase; April 14, 2021 at 10:09. Reason: wrong link |
April 14, 2021, 10:53 |
#12 | |
Kira
Rep Power: 8 |
hexa, icem, pre-mesh |
[ICEM] Missing face critical error while importing icem mesh to fluent | tuhin | ANSYS Meshing & Geometry | 4 | March 12, 2018 08:20 |
[ICEM] Creation of hexa dominant mesh and prism layer | gnuboard | ANSYS Meshing & Geometry | 7 | January 11, 2018 04:13 |
ICEM Pre Mesh Params | Flashidashi | Main CFD Forum | 0 | February 26, 2015 01:23 |
[ICEM] trouble with mesh quality from ICEM in CFX Solver | escher25 | ANSYS Meshing & Geometry | 0 | February 28, 2011 07:38 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
