[ANSYS Meshing] Not able to create structured mesh for 2d airfoil |
Anupam Krishnan
Rep Power: 0 ![]() |
I am trying to study the lift characteristics of a modified airfoil using face meshing. I have divided the fluid domain into 6 using face split, but one of the split faces doesn't mesh properly when face meshing is used. What might be the reason? |
sila
Rep Power: 12 ![]() |
I advice you to use ICEM CFD to have better control in Meshing. This kind of problem can be easily solved in ICEM CFD. If you have any queries contact me through silambarasan7@gmail.com Regards, Silambarasan P |
Kira
Rep Power: 8 ![]() |
Have you done any vertex associations for this? If so, make sure they are associated to the correct entity. |
Anupam Krishnan
Hi Kira,
Treat me as a novice in Ansys. Could you please elaborate vertex associations? I am using ANSYS Meshing (not ICEM) for my model. |
Kira
Hello Anupam,
I now see the [ANSYS Meshing] in the title, sorry about that, I was talking about ICEM. I also realize that the association I was talking about is for unstructured mesh as well, I do not think it is used with structured meshing. It is similar in ANSYS Meshing as in ICEM; within the association menu there is an option to associate entities (its a yellow hand/finger). There you can choose the vertex/edge/face(s) to associate. But again, this would be for unstructured, so unless you wanted to convert it to unstructured, it would not apply. So my suggestion would be to double check that all of your surfaces are present, I believe issues such as this are often caused by missing surfaces. |
Rep Power: 6 ![]() |
I dont know why but the mesh is warping at the end . I have tried sizing and biases of different sizes , nothing seems to be working
jose daniel
I suggest you visit https://aeroptimal.com/mesh (you must create an account to use this module), where you can create a full structured airfoil mesh - https://youtu.be/4Opu0zk7gFk . You can export .su2 .msh .foam .vtk
2d airfoil mesh, face meshing |
[ICEM] 2d Undtructured mesh around airfoil with boundary mesh | samiyare | ANSYS Meshing & Geometry | 2 | September 21, 2013 00:29 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
