[ICEM] What can I do if my middle button doesn´t work? |
October 22, 2009, 15:14 |
Juan
Rep Power: 16 |
Hello again, I´ve a problem, my middle button seems doesn´t work, in some operations I have to press for accept the selection of curves (for example), when I do it, the selection desappears. What can I do?
Thank you. |
October 23, 2009, 08:51 |
Mouse...
Simon Pereira
Rep Power: 47 |
If you don't have a middle mouse button (such as on a laptop), you can click left and right buttons simultaneously. I have always found that too awkward to work with though.
Are you saying your mouse just doesn't work properly or that ICEM CFD is not properly recognizing the mmb? If it is the mouse, I recommend a new mouse. If it is the software, that is the first I have heard of this problem... Please give more details. Is it a specific command or every command? What is happening? |
October 26, 2009, 12:16 |
Juan
Rep Power: 16 |
Hello, I´m going to explain my problem.
I´m doing the tutorial that describes how to repair the geometry. I have to remove a hole, the tutorial´s steps are: –Select any one of the boundary curves on the hole –Press “l” (lower case L) on the keyboard or Select all items attached to current selection in the Select geometry toolbar –Selects all curves tangentially attached to the selected curve (“flood fill”) –Selection restricted to yellow (single edge ) curves –Middle mouse, then hit Apply –Press “y” to accept the surface When I press the middle mouse (in my mouse is a wheel), the selection desappears. I change the mouse and I had the same problem. I try to pulse left/right buttons at the same time but nothing changed. |
November 2, 2009, 19:36 |
Ends the selection
Simon Pereira
Rep Power: 47 |
When you use this command, the middle mouse button ends the selection.
Then it switches to preview mode. If your background is set to black, this is easiest to see. It asks you to select "y" or "n". If you select yes, then it creates the surface. When you hit the middle mouse button (I also have a wheel mouse on Windows), does it ask you for "y" or "n"? What happens when you select "y" or "n"? |
November 9, 2009, 11:32 |
Juan
Rep Power: 16 |
Thank you for your help, now I don´t have the problem because I changed my mouse.
Thank you again. |
November 20, 2020, 11:31 |
icem
reza sayareh
Rep Power: 8 |
hi guys, i am using ICEM 2020, while i want to rotate by holding left mouse bottom it goes to creating point directly .pls help
November 22, 2020, 02:23 |
CFD Expert
sila
Rep Power: 12 |
Change the mouse settings in ICEM software
Thermal Radiation doesn´t work?! | ehrenwirth | CFX | 14 | June 4, 2009 18:54 |
Middle button disabled within ICEM | Rikio | CFX | 0 | March 25, 2008 20:07 |
Button 'Generate Mesh' doesn't work | Julie Polyakh | Siemens | 3 | January 7, 2004 18:15 |
Middle mouse button | Pascale Fonteijn | CFX | 2 | March 27, 2003 03:06 |
Middle button | Nar | CFX | 2 | April 8, 2002 07:18 |
