March 7, 2021, 23:29 |
how to avoid mesh elements in gap?
Iharshavardhan reddy
Rep Power: 5 |
I was making a Tet mesh to a geometry that had a very narrow gap between two surfaces. After generating mesh, the mesh elements are going inside the gap. How to avoid that?
I am attaching images below. |
March 8, 2021, 02:20 |
Gert-Jan
Rep Power: 27 |
Remove all points and curves that are not necessary to represent your geometry.
March 8, 2021, 02:41 |
Rep Power: 5 |
Thank you for your reply sir.
I removed all curves and points and done 'built topology' and set surface max size to all surfaces and done octree mesh. |
March 8, 2021, 02:57 |
Gert-Jan
Rep Power: 27 |
Tr increasing your minimum size
March 8, 2021, 04:01 |
Rep Power: 5 |
Sir, I was given different surface mesh sizes. When I do surface mesh that hole is capturing well. when I do volume mesh by Delaunay that is not capturing well in volume mesh. What to do sir? ( I have given 0.1mm for that thin wall edge)
March 8, 2021, 05:08 |
Gert-Jan
Rep Power: 27 |
1) If there is a hole, then close it with a surface. Remove all curves and points that are unnecessary to describe your geometry.
2) I never use Delauney, so I don't know. 3) Use Robust Octree. Go to Global Mesh Setup. Disable Curvature/Proximity Based Refinement. And off you go. 4) In you first post, you have written something in red on a blue backgrund. Impossible to read. And where is this in your geometry. It is unclear to me |
March 8, 2021, 05:40 |
Rep Power: 5 |
Sir, I am attaching the figure. That gap should be maintained in my geometry.
In surface mesh, it is capturing well but in volume mesh, it is not capturing. I tried edge criteria of 0.02 and defined thin cuts also. still problem not solved. |
March 8, 2021, 06:13 |
Gert-Jan
Rep Power: 27 |
Better not include the gap. Why not make it an internal surface? That is much more efficient:
1) Reduce it to a single surface 2) Give it a unique name 3) Go to: Mesh > Part Mesh Setup > Internal Wall or Split Wall And off you go. |
March 8, 2021, 06:41 |
#9 |
Rep Power: 5 |
Sir, actually we made a gap because prism layers transition will be good. Is it possible prism layer transition will be good at a sharp corner( without gap). Those two are walls with a 1mm gap.
March 8, 2021, 08:00 |
#10 |
Gert-Jan
Rep Power: 27 |
You can extent the surface at the tip, give the extention a unique name, apply inflation (prisms) on it, but in the modelling, do not define it as a wall.
The prisms on the extention, hanging in the volume around the tip will be part of your volume mess, which should be completely fine. |
GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 11:33 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] Nuclear fuel assembly, Mesh Check: "missing internal faces, uncovered faces" | swparth | ANSYS Meshing & Geometry | 2 | June 27, 2017 07:12 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
