[DesignModeler] I can't create lines from sketches |
January 27, 2021, 17:46 |
enis
Hello everyone,
I want to do 2D flow analysis for NACA 4412 airfoil. I am applying the example linked below. When I do the line creation process that is being done between 6:15-7:25 in video, there are always 3 lines instead of 4 lines and I cannot do the projection process. I wonder if there is a problem in my coordinates or what is the problem? I've been working for two days, I would be very happy if you could help. Thank you. https://youtu.be/0rH4tMcV1c4?t=375 ss https://ibb.co/PYX8cgq https://ibb.co/m5KWhVf https://ibb.co/6wRK0x3 airfoil dat https://easyupload.io/ljnbp2 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
[GAMBIT] How to plot S pipe | mariam.sara | ANSYS Meshing & Geometry | 36 | November 7, 2013 15:22 |
[ICEM] how to create a 2d tri mesh with quad mesh in the boundary layer | seal2013 | ANSYS Meshing & Geometry | 3 | October 6, 2013 16:09 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
