[ICEM] cubes on block edges
Old   June 22, 2011, 07:14
Default cubes on block edges
Max
murx is on a distinguished road
PROBLEM SOLVED
I have a distorted mesh which is caused by cubes on the block edges shown in the picture below. I assume that these cubes are relics of a split block that I re-merged. I have tried a lot to get rid of the cubes but nothing worked. Can anybody tell me what exactly they represent and how to delete them?
Thanks!
Some more info:
- they seem to be part of the edges - if i disable edges in the display tree, they disappear
- the lines between the cubes are separate edges although those edges are only separated by the cubes, not by vertices
murx is offline   Reply With Quote
Old   June 22, 2011, 07:33
Max
Figured it out:
Edit Edge --> Unsplit Edge
Old   February 21, 2021, 21:01
Domoina
Domoina is on a distinguished road
Originally Posted by murx View Post
Figured it out:
wow! thank you
Domoina is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Delete block edges in ICEM CFD YK CFX 1 June 22, 2008 14:30
