March 26, 2021, 21:17 |
Around Block in Ogrid ICEM
Mercurial
Rep Power: 5 |
Hey all,
I'm just trying to get into CFD using ICEM I have a problem about my O-grid Now when trying to make a O-grid, i don't understand what is Around Block(s) and how to use it. I saw that everyone usually use Offset 0.5 or 1 for Around Block(s). I have 2 question about it: 1. What is Offset ? Is it a quantity same millimeter or meter....? 2. When do we use Absolute or not ? |
March 26, 2021, 23:51 |
Kira
Rep Power: 8 |
1. Offset specifies the height of the O-grid layer and behaves like a relative distance: A value of 1 places the O-grid at a location where the resulting blocks will be distorted the least. Increasing the value makes the inner blocks of the O-grid smaller, with the surrounding blocks larger, and vice versa for decreasing the value.
2. Enabling Absolute would allow you to specify the actual length of the radial edge of the O-grid i.e. assigning a Offset of 5 would make all the radial edges of the O-grid 5 units (same as your geometry units) in length. |
March 27, 2021, 01:33 |
#3 | |
Mercurial
Rep Power: 5 |
March 27, 2021, 04:43 |
Mercurial
Rep Power: 5 |
Hello, i overcame the problem about Around block but the new issue comes when i try moving into the Fluent. The system said i have non-positive volume. I actually dont know what is negative volume, how it affect and how to detect it in ICEM and fix pls. Can u help me? Thanks
March 27, 2021, 11:26 |
#5 | |
Kira
Rep Power: 8 |
Run a mesh check in ICEM and show me a photo of the output along with the mesh. It will show you the locations of the negative volume elements. Highlight these elements then we can discuss how to fix it. |
[ICEM] Correct blocking and Ogrid in ICEM | salumi | ANSYS Meshing & Geometry | 3 | November 8, 2016 10:10 |
[ICEM] what is free block type in icem cfd? | nauman55 | ANSYS Meshing & Geometry | 1 | January 16, 2014 06:12 |
[ICEM] Bottom-Up Block in ICEM | cfd seeker | ANSYS Meshing & Geometry | 1 | July 7, 2013 04:33 |
Domain size icem cfd block mesh | erhan61 | ANSYS Meshing & Geometry | 1 | March 29, 2011 09:39 |
Number of elements in ICEM block? | Pete | CFX | 1 | December 2, 2004 22:45 |
