[DesignModeler] Issues with skin operation
Old   May 13, 2021, 12:02
Default Issues with skin operation
Vaelyn is on a distinguished road
Hello everyone,
I'm having trouble closing the solid in the image below with a simple skin operation between the faces.
Actually, the operation is successful depending on the angle "a" between the two bodies. For example, it doesn't works at angles of 1, 2, 4, 6, 7 degrees, but it does work at 3 and 5 degrees. Even more strangely, while it works at 3 degrees it doesn't work at 3.001 degrees.
Thank you in advance.
EDIT: I do know there are other ways to do it. Creating a surface between the the top edges and extruding it to the bottom of the gap did work, but i want to make it "cleaner".
Vaelyn is offline   Reply With Quote
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 12:35
Finding Drag Force from Skin Friction Rob Wilk Main CFD Forum 0 May 8, 2020 06:04
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 04:14
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 16:18
