August 25, 2021, 06:02 |
HOW to mesh sharp corners
REZA
I tried to use face meshing but it doesn't affect the sharp part of my geometry, how can I fix it ?
September 12, 2021, 15:12 |
Rep Power: 17 |
Seems you are trying to do a mapped meshing here, which essentially is a rectangular mesh. This is not possible to fit inside a tight angle like this. For what purpose do you want a mapped mesh here? You can probably get finer mesh in the pointy region by using biased edged sizing.
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
How to mesh sharp corners in ICEM CFD | abhilasht | ANSYS Meshing & Geometry | 1 | January 8, 2019 09:53 |
Meshing sharp corners - mesh for a MVG | fportela | Mesh Generation & Pre-Processing | 0 | March 17, 2013 11:33 |
