[ICEM] ICEM - 3D MultiZone - Wing-Fuselage Configuration |
September 9, 2021, 00:42 |
bakar
Hi all !
I am making grid for fuselage-Wing configuration using ICEM CFD. The steps are as : 1. geometry and topology build 2. Create block -> 3d Multizone 3. Move/merge vertices, Split Free Face 4. Modify mesh size of different surfaces for smooth mesh. 5. Convert free faces to mapped (wing leading edge, wing upper and lower surface) The resulting mesh is shown below. 6. Now, there are 300 mesh point along the airfoil. 7. I need to increase it to 600. So I decrease the mesh size on upper and lower surface of wing. Now I am getting two types of errors. ERR 3105: boundary node lies within face near (xxxxx, yyyyy, zzzz) ..... ..... ..... ERR 3009: edge near (xxxxx, yyyyy, zzzzz) is missing ..... ..... I have also checked surface mesh at these location. Mesh looks fine. Is there any solution for this problem. Thanks |
ICEM Wing Mesh Problem | andrewmichael | Mesh Generation & Pre-Processing | 0 | March 4, 2018 17:30 |
[ICEM] 3D wing + wingtip meshing in ICEM | AdriC | ANSYS Meshing & Geometry | 3 | February 22, 2016 11:14 |
[ICEM] unstructured wing mesh generation in ICEM CFD | arunintn | ANSYS Meshing & Geometry | 3 | March 6, 2013 17:05 |
Negative Fuselage Drag on a Tandem Wing? | mmn1239 | STAR-CCM+ | 3 | April 28, 2012 08:20 |
Negative Fuselage Drag on a Tandem Wing? | mmn1239 | Main CFD Forum | 1 | April 7, 2012 04:52 |
