[ANSYS Meshing] icem hexa meshing
Like Tree1Likes
  • 1 Post By mluckyw
Old   September 30, 2021, 00:57
Default icem hexa meshing
Amit Parmar
param is on a distinguished road
hello
i am making a mesh file of a geometry(warehouse having leakage point at some distance from bottom) but the mesh quality is poor and therefore it is not working on ansys fluent.
My procedure is as follows:
1. points < lines < surfaces < create parts < blocking < association of vertices only < splitting < deletion of leakage part block < pre mesh parameters < convert to unstructured mesh < mesh file.
After which step i have to associate curves?
But after doing this the mesh quality is very poor and floating point error is coming in ansys fluent.
plz help me
Amit Parmar
param is offline   Reply With Quote
Old   September 30, 2021, 06:03
Chrowale
mluckyw is on a distinguished road
I don't quite get what is your problem in your case. What are you trying to do and what's the geometry that you are working with. Another question is why are you doing the delete block? is there a wall or object in there?
Have you check the mesh using ICEM check mesh? Usually I don't do delete block in Hexa-mesh unless you have a Boolean in your geometry
mluckyw is offline   Reply With Quote
Old   September 30, 2021, 07:30
M
AtoHM is on a distinguished road
Impossible to say with this information, probably a wrong association.
If you are not sure how the associations work, go through the basic tutorials, its covered there nicely.
With the angles you have there, no code will ever run. You can click at the bins of the quality diagrams to see in the viewer where the bad elements are. This should at least indicate where your associations are wrong. Also in the menu to the left, you can activate Edges->Show Association, which gives a nice representation of the associations.
Good luck!
AtoHM is offline   Reply With Quote
Old   October 2, 2021, 02:24
Amit Parmar
firstly sir thanks to you that you noticed my problem.
i am working on problem that is cuboid shape (12*5*3 dimension) warehouse and a small leakage point of h2 gas (0.305*0.305*0.15 dimension) in bottom plane. So i am generating mesh of this above case but the mesh quality seems to be poor.
So what series of operations i should followed to generate mesh of this case?
thank you
Amit Parmar
Old   October 2, 2021, 02:31
Amit Parmar
Good luck!
firstly very very thanks to senior member that you saw my problem
sir firstly i associate first block with the warehouse and then splitting the block and then at last associate the small block with leakage part.
Can you guess at what point i am missing something?
thank you
Amit Parmar
Old   October 2, 2021, 05:12
Chrowale
Have you tried using O-grid for the whole warehouse except the leakage block? that might helped to a certain extent.
For association problem it's quite impossible to do it without the picture of the shell mesh to the least, can you post it?
AtoHM likes this.
3D Airfoil ICEM Hexa Meshing Skewness Issues AamirSultan Mesh Generation & Pre-Processing 0 December 1, 2018 16:16
[ICEM] complex 2D meshing on ICEM kassab ANSYS Meshing & Geometry 26 April 14, 2014 21:02
[ICEM] Domain shape for meshing missile - ICEM HEXA Far ANSYS Meshing & Geometry 5 July 31, 2013 14:34
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 10:28
[ANSYS Meshing] Hybrid meshing ICEM djoul ANSYS Meshing & Geometry 2 January 17, 2012 18:18
