October 4, 2021, 05:25 |
Periodic surfaces matching mesh
Rep Power: 6 |
hello everyone,
I am a beginer in ICEM. When generating periodic surfaces mesh on Ansys Meshing you have the option to create matching surface meshing which is needed for periodic rotation. Is there a similar option on ICEM ? if not, how do you ensure that the mesh on the intended periodic surfaces is the same ? Thank you |
November 2, 2021, 10:49 |
Gert-Jan
Rep Power: 27 |
This is possible in the menu Mesh>Global Mesh Setup>Set up Periodicity
November 3, 2021, 04:57 |
Rep Power: 6 |
icem, periodic boundary |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
periodic straight tube flow, no mesh independent solution for pressure gradient | thijs1909 | FLUENT | 5 | May 16, 2018 09:04 |
Mesh Independance Test VS Matching CFD Results with Experiments | fadoobaba | FloEFD, FloWorks & FloTHERM | 5 | May 10, 2018 08:49 |
How to make periodic two faces of identical surface and different mesh | dmaz | ANSYS | 1 | September 7, 2015 16:08 |
