October 9, 2021, 13:45 |
Meshing Journal Bearing
kukka
Rep Power: 7 |
Hi!
I started working on journal bearing recently to explore the hydrodynamics pertaining to the lubricant. I am considering the thin film regime alone and not the solid part for analysis. In this, first, the clearance is very small, somewhere around 30 microns. Second, due to eccentricity of the shaft, the gap reduces further in a particular region. At first, I tried meshing on ICEM CFD, but the cells seems to be of very poor quality (negative (-1) 3x3x3 quality cells) despite carefully splitting and associating the block edges. Thereafter, I tried to mesh it in workbench. I split the geometry first and then provide number of divisions on each edge and have applied sweep technique. Here again, I got very poor cells. I am using solidworks to generate the solid model, and saved the mesh in parasolid, step as well as ACIS format, but nothing worked. Any suggestion on the above would be a warm welcome. |
Using dynamic mesh in Journal bearing modelling | aminepoxnet | FLUENT | 0 | July 18, 2015 16:11 |
Boundary condition for journal bearing | swagat1234 | Main CFD Forum | 1 | July 14, 2015 04:01 |
solving finite journal bearing problem by finite difference | Atit Koonsrisuk | Main CFD Forum | 6 | March 29, 2015 08:09 |
how to draw journal bearing fluid using gambit?? | zidane | FLUENT | 0 | March 8, 2009 12:40 |
Gambit Journal File Scripts, Public Database Needed? | Jonas Larsson | Main CFD Forum | 13 | March 2, 1999 07:25 |
