[ANSYS Meshing] How do I open a mesh made in Ansys Fluent 2020 R2 on Ansys Fluent 2019 R3? |
November 2, 2021, 18:05 |
CA
Rep Power: 6 |
How do I open a mesh that was made in Ansys Fluent 2020 R2 on an older version of Ansys Fluent? Specifically Ansys Fluent 2019 R3. I'm trying to open someone's Ansys Fluent file but it won't let me open it because I'm on an older version of Ansys.
Is there any way to just open the mesh in the older version of Ansys without having to upgrade? |
November 3, 2021, 06:57 |
Stuart
Rep Power: 25 |
If I recall correctly you cannot open a newer file in an older version of ANSYS. You can open an old file in a newer version of ANSYS.
November 3, 2021, 12:29 |
#3 | |
Erik
Rep Power: 23 |
I don't know of a workaround for mesh files. But I have been able to get some material files to work by modifying the file with a text editor (notepad) and replacing the newer version numbers with the version number I'm using. May not work for meshes though, material files are much simpler. Good luck. |
November 3, 2021, 15:44 |
Gert-Jan
Rep Power: 27 |
I have seen ICEM to be more forgiven with respect to version issues. So you can try to import the .msh-file in ICEM and then export it as fluent again. However, succes not guaranteed.
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
