November 23, 2021, 14:21 |
Trouble with meshing
Dan Gotesman
Hello all,
I created a 3d geometry on Solidworks that consists of several bodies. when I try to multizone block it and than mesh it fluent doesnt see the connected surfaces between the bodies as a shadow wall. when I do volume mesh with the default settings fluent does see the surfaces as a shadow wall. I dont want to use the volume mesh because it leads to other problems I encountered with fluent reading the mesh and getting solution, thats why I wanted to try block meshing. I am looking for help on how to get the surfaces between the blocks to be coupled and for fluent to see them as shadow walls. I am new with meshing and fluent so thanks in advance. |
[ANSYS Meshing] Parallel meshing utilisation failing | crc1622 | ANSYS Meshing & Geometry | 0 | February 14, 2019 02:42 |
I have big trouble in meshing the space of a hollow cylinder | zaxfly | ANSYS Meshing & Geometry | 6 | September 8, 2014 19:37 |
[GAMBIT] Trouble meshing complex VOF geometry | RPJones | ANSYS Meshing & Geometry | 2 | February 14, 2011 18:54 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Trouble with meshing in Pro-am | NALLELI | Siemens | 1 | July 13, 2005 03:41 |
