[TurboGrid] Centrifugal Impeller Expansion Ratio Problems
Old   August 5, 2022, 06:22
Question Centrifugal Impeller Expansion Ratio Problems
Daniel
zacko is on a distinguished road
Hello there,
I have a small question regarding the meshing of an centrifugal impeller with a y+=~1. In the provided images you can see my current mesh. I marked the area I'm a bit unsure about how to refine this region.
I directly specify my estimated Reynolds Number and my desired y+ value of 1 (see the mesh data).
Also, I activated "Target Mesh Expansion Ratio" which I set equal to 1.15.
But, for me, the marked area does not have an expansion ratio of max. 1.15. I don't know if my TG Version (2022 R1) has a bug or this setting is working different than I assume.
I would really like to add more cells into this region, so the expansion ratio is better. Am I missing something here ? Maybe you can help me. I can't imagine that this is so hard - but still, I don't know how to solve this issue.
Thank you very much in advance for any tips and tricks!
Greetings
Daniel
zacko is offline   Reply With Quote
Centrifugal pump impeller simulation doesn't converge JuanRincon CFX 8 June 25, 2019 05:59
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Problem : Cell expansion ratio (blockMeshDict) ysh1227 OpenFOAM Pre-Processing 10 September 10, 2012 04:12
Problem rose from centrifugal impeller tim_shute FloEFD, FloWorks & FloTHERM 6 January 31, 2012 20:06
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
