[Other] How to create a perfectly flat surface in Spaceclaim? |
November 8, 2022, 19:54 |
Lucas Pelizzari
Rep Power: 4 |
I have the geometry of an airplane cut in half, like this:
To generate the fluid domain in Spaceclaim, I have to create a rectangle around the geometry at the plane of symmetry and then extrude it (correct me if I'm wrong). The problem with that is, when I fill the remaining face of the geometry like this: it creates a not-flat surface, which absolutely ruins the fluid domain generation step. It is barely noticeable here, but you can see the surface bulges out just a little bit. When I try to cut one surface from the other, it actually works, but it creates a hole in the fluid domain. How do I generate an actually flat surface in this situation? |
spaceclaim |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 09:26 |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
[snappyHexMesh] How to create internal boundaries using snappyHexMesh | robyTKD | OpenFOAM Meshing & Mesh Conversion | 2 | October 19, 2014 09:57 |
[DesignModeler] Design Modeller create surface | papis | ANSYS Meshing & Geometry | 0 | October 31, 2013 13:52 |
