[BladeModeler] BladeGen problem in creating turbine blade |
July 2, 2023, 12:33 |
Aja
Rep Power: 14 |
Hi friends
I have a problem to create a rotor geometry of an axial turbine. In fact, when i use from following path to shift model, geometry of blade changes. Why? Tools>shift in z direction Also, the pictures have attached. Thanks a lot |
July 2, 2023, 17:58 |
Aja
Rep Power: 14 |
No body can help me in this problem?
July 3, 2023, 00:41 |
Daniel
Rep Power: 9 |
You only shifted your meridional path. Your meridional path is defining your inlet and outlet points of your domain. Your blade geometry should lie in this area, in order to generate the blade as wanted.
Is there a reason why you need to shift the path in the first place? Either move the blade profile as well, find a room that shifts both or, if you use CFX or fluent later on, shift everything there using the transform function. Last edited by zacko; July 3, 2023 at 02:01. |
July 3, 2023, 12:33 |
#4 | |
Aja
Rep Power: 14 |
I am designing stator and rotor together. The stator and rotor must be correctly aligned in terms of spatial coordinates. The spatial coordinates of the stator output should be equal to the spatial coordinates of the rotor input. Can you tell me exactly which directiry I should do this work in the BladeGen to solve the problem? |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 05:27 |
Gas turbine blade cooling | Sagnik648 | System Analysis | 0 | July 10, 2019 04:55 |
CFD_screening problem for Francis Turbine Optimization | berk can | Fidelity CFD | 3 | February 22, 2014 12:08 |
[ICEM] Problem with Y+ elements in 3D blade mesh | SlapGas | ANSYS Meshing & Geometry | 12 | September 12, 2013 11:40 |
[Other] ANSYS CFX-Meshing problem of a wind turbine blade | Zoe | ANSYS Meshing & Geometry | 1 | July 14, 2010 02:02 |
