[Other] Enveloping an irregular solid with a certain thickness |
July 5, 2023, 04:54 |
Rep Power: 2 |
Hi. I'm new here.
I would like to ask help regarding this geometry that I initially prepared: I wanted to make an enclosure for this geometry in SpaceClaim, but what I see from guides are simple box, cylinder, and sphere enclosures. What I wanted to happen is to make another solid that would enclose the entire thing that is about 5 millimeters thick at all sides. That way, when I suppress the solid I have prepared I would have a hollow solid that is similar to this thing that I prepared that is 5mm thick. How can I achieve this? Thank you! |
July 5, 2023, 05:06 |
Daniel
Rep Power: 9 |
Try the shell feature.
July 5, 2023, 05:57 |
Chrowale
Rep Power: 4 |
Another way to do this:
You could make another copy of the solid and scale it until it reaches the desired distance from the original body. Detach all of the solids to turn it into surfaces and make two solid that has a gap in the middle for the original body, then combine those two bodies. Last edited by mluckyw; July 5, 2023 at 06:01. Reason: Wrong suggestion, this is better than the previous one. |
July 5, 2023, 06:37 |
Rep Power: 2 |
July 5, 2023, 06:38 |
#5 | |
Rep Power: 2 |
I actually had this idea initially, then I started to think how can I make sure that the thickness of the resulting hollow solid would be 5mm. |
July 5, 2023, 06:53 |
#6 | |
Rep Power: 2 |
Then now I have this issue that I cannot separate the prepared shell from the original body. Any ideas what should I do here? |
Daniel
Rep Power: 9 |
July 5, 2023, 06:56 |
#8 | |
Rep Power: 2 |
My issue now is how to separate this shell generated from the solid. It just shows as a single solid in the structure pane (actually this is the reason why I didn't even realize that I already made the shell. There's nothing 'new' appearing in the structure pane). EDIT: This is what I mean: I managed to see that there is a shell by deleting one of the shell's faces. My problem is I cannot separate this generated shell from the solid formed. Last edited by maistral; July 5, 2023 at 07:02. Reason: Added photo |
July 5, 2023, 07:32 |
#9 |
Daniel
Rep Power: 9 |
So, in your feature tree I can see a solid and a surface body.
But you only did get the surface body due to deleting of one face, correct? If you would have not deleted that face, you only had one solid? |
July 5, 2023, 07:49 |
#10 |
Rep Power: 2 |
Yeah. That is correct. Anyway, I managed to do it! This is so much fun Apparently if I have a surface of a body and used the shell function it converts that surface into a shell, going inward (so if I want a 5mm thick hollow object, I have to prepare 5mm in advance when preparing the solid). I learned something new. Thank you!
July 6, 2023, 01:46 |
#11 |
Daniel
Rep Power: 9 |
Great to hear! Yes, I tried it out yesterday and also saw that it goes inwards. I tried to enter a negative number but it didn't work haha
Solid combustion problem.... | godspeedsam | FLUENT | 3 | May 24, 2022 04:29 |
Structural analysis- bosy surface part from the solid part | andreina | Structural Mechanics | 0 | October 12, 2015 09:56 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
How model radiation of both solid wall and fluid£¿ | Harry Qiu | FLUENT | 2 | February 3, 2013 23:04 |
properties of solid mixture | Ahmed Khattab | OpenFOAM | 0 | December 26, 2012 13:59 |
