[ANSYS Meshing] Very long cells that don't match mesh edge sizing settings |
August 11, 2023, 13:02 |
Karem Elmahalawy
Rep Power: 2 |
Good evening all,
While performing meshing, I did mesh sizing using number of divisions with bias. the mesh created was structured but in the inflation created some cells were very long and are not divided as the setting divisions was which in turn made the aspect ratio very high (82,000). What should I do to make all cells as structured as I want and to improve mesh quality? Thanks |
August 22, 2023, 14:42 |
Erik
Rep Power: 23 |
Are you using Hard or Soft behavior? Soft will ignore you sometimes, so try using hard behavior.
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
