[Other] Trouble with pull command in spaceclaim to create cyclone outlet |
September 14, 2023, 11:05 |
Andreas Gerstmayr
Hi folks,
this is my first post on this board and I am currently trying to getting used to Ansys mostly for Fluid Flow simulation. I am working on a cyclone separator to simulate dust particle separation and I am currently struggling with a seemingly very easy geometry. My issue is that I cant find a way to create the pipe outlet of the cyclone on the top. I created a solid cylinder by the pull command of a circular surface. I made a second, smaller circle with the outlet inner diameter but when trying to cut with the pull command, it cuts away the inlet as a whole instead of creating the desired hole. This issue sounds super simple, but I am stuck. Thanks so much for any advice! Last edited by Gersteloni; September 14, 2023 at 11:07. Reason: Pic upload |
September 21, 2023, 05:38 |
Gert-Jan
Rep Power: 27 |
Default action is "Hinzufügen". Therefore you should tick "Ausschneiden".
Did you do that? |
geometry, pull |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
